Old 06-29-2023, 09:58 AM   #1
Patch56   Patch56 is offline
Hawk 250 front forks
Good morning,
Does anyone have a good suggestion on front fork pre load spacers for a Hawk 250, diameter, length, type of material? I have read anything from 17mm sockets to PVC, to washers? Any suggestions would be great.
Old 06-29-2023, 10:16 AM   #2
I have PVC pipe. Don't remember right of hand on the length I used. I put them in there years ago. lol
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 06-29-2023, 05:28 PM   #3
Thanks Jerry
Old 07-02-2023, 10:32 AM   #4
My Hawk still has whatever they put in when they hammered it together, but I did a lot of tuning and suspension work on my DR-650. I found the easiest way to get a really nice ride was to buy a length of Schedule 80 PVC pipe, and start cutting hunks off it. Schedule 80 PVC is dark grey in color, and has nearly twice the wall thickness of the white schedule 40 you can get at the big box stores. You'll need to let the Google be your guide to find a plumbing supply house near you that has schedule 80 PVC in stock. I used a 1" pipe diameter for the DR, but I think with the Hawk being smaller and lighter it would probably use 3/4" or maybe even as small as 1/2". I would carefully measure a couple lengths out (start with something like 2", 2-1/2", 3") and then just put them in and go for a rip. It's super easy to get the fork caps off, just loosen the triple clamp bolt, and unscrew it, so changing out your lengths for testing shouldn't be any problem. Just make sure when you do your testing, you give it an honest shake for the riding you're going to be doing the most. Hope this helps!
First Rule of Aviation:
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 07-05-2023, 05:18 PM   #5
Fork spacers
thank you Emerikol !!! Great help!
front forks, pre load, spacers
