Nibbi 28pe
Replacing pz30 with nibbi 28pe. Looking for recommendations on where to start jet wise.
Hawk 250 decat, 4degree advance, ported & polished head shaved 1mm. Elevation approx 1000 ft mostly ridden in 80 to105 degree temperatures. First time nibbi user. Arrived today with 1 extra pilot and 3 extra main jets. Have not checked installed jets yet. Included instructions seem pretty useless. I'm assuming the brass screw near the intake is the idle air adjustment as the only other screw appears to be the bowl drain. Haven't really had a chance to look it over yet. But thought someone here would know more about it than me. TIA Billy
At least a 125 main. I would suggeat starting with a 130 or 135 to be safe. My ported head with a cam (also 1mm decked) ran a 145.
Pilot, I found the 38 to work the best for me. 35 was a tad lean at 1/8th throttle, but, again, cam involved that may slightly change things. Mixture screw on mine was at 1 3/4 turns out The brass screw near the intake is the idle mixture screw, and adjusts air. Open - leaner, close - richer.
#4 | |
![]() Quote:
I am sure there are springs out there that work, but I haven't had an issue yet so I never looked into it.
