05-24-2008, 11:12 AM | #1 |
Engine hot in Traffic Jam
So, I was stuck in a traffic jam. Every minute of so, we would inch forward a bit in a totally miserable fashion. I, with my full face helmet and a nylon jacket, was getting overheated. The engine also was getting hotter and hotter. I can feel it. Since I don't have a temperature gauge, I don't know how hot the engine actually was. Should I worry about it? What happens if the engine get too hot? Will it permanent damage it? I know that in car engines, overheating them is a very, very bad thing. So, I wanted to lane split, to get some air on the engine, but cagers here generally fly into rage when motorcyclists do that. Besides, I don't feel comfortable doing that when my bike has such wide handlebar and mirrors.
Chinabikeless |
05-24-2008, 12:39 PM | #2 |
When I was waiting in line at the border for 45 minutes (on my liquid cooled vulcan mind you), I turned the bike off and pushed it forward when the cars crept ahead.
05-24-2008, 12:57 PM | #3 |
Fortunately I don't get into that kind of traffic often, but I like the shut it off idea.
Allen
05-24-2008, 01:28 PM | #4 |
Yes you can do damage and yes I would agree to shut it off. Without air moving over the cooling fins, you are baking it by just setting there. To answer your question though, eventually if it gets hot enough it will seize the engine.
05-24-2008, 01:59 PM | #5 |
At what point do I need to shut it off? I mean, how do I know it's getting too hot?
Chinabikeless |
05-24-2008, 02:05 PM | #6 |
I never let the bike sit and idle for more than ten minutes or so unless it was warming up. I was probably being overly cautious but thats just me
05-24-2008, 02:24 PM | #7 |
You might want to change your oil and when doing so you might be able to tell via smell if it has been cooked. Also when a engine starts to overheat it will lose noticible power before it siezes up. When you were able to give it a little gas did you notice any power loss? If you didn't then I doubt it was hot enough to do engine damage. If it did lose power then damage may have occured, but that would depend on the quality of the metal of the engine componants. Keep in mind that (at least the japanese dirtbikes) they are designed to be covered in mud and still take a beating all day long, so hopefully your bike is ok. I had a DR350 and I probably cooked that engine a half a dozen times where the engine would give off an odor, kinda like a burning clutch or brakes and it lasted 12,000 (mostly off road) miles before I had to have new rings and the cylinder honed out. I do like the idea of shutting off your motor and just pushing with your feet while in stop-n-go traffic. Good luck.
05-24-2008, 02:25 PM | #8 | |
I won't lane split. I might consider the shoulder, but only if I'm really desperate.
2008 American Lifan LF200 GY-5 (930 km) - Sold 2007 Kawasaki EX250 - Sold 2006 Kawasaki EX650R - My new ride! 2005 Kawasaki EX250 - A new project |
05-24-2008, 07:01 PM | #10 |
If you are gonna have to run much city traffic, I'd invest in one of these:
http://cgi.ebay.com/Traxxas-Blue-On-...QQcmdZViewItem I run them on my Nitro RC cars. The wire lead just mounts on the head and reads the temp. It gives a digital readout. Then you could get a baseline temp and when it starts to creap up in traffic you could shut it down.
05-24-2008, 07:53 PM | #11 |
Just as an aside, I've found with the ATVs at least, when they get really good and baked, i.e. sitting idling for extended periods, or torquing up a long hill in first, etc. I've found that they develop a very distinct low speed ping when they're getting good and hot. I kinda figure, no ping, no problem. (Ping even more distinct with the "knothead mod.")
--Vince
"Sometimes it is better to say nothing, and let people think you're an idiot, than to open your mouth and prove it." |
05-24-2008, 10:24 PM | #12 | |
-2005 Sierra SR200- |
05-25-2008, 01:45 AM | #13 |
what type of oil do you run in it :?:
check the viscosity of it , thats the brake down point (heat) thats usualy about ? 250, 350, 500, degrees something like that , or higher ? look on the bottle for an 800 # for questions and give them a call , they'll tell you at what temp the oil starts to break down, if its way up there like 1000 deg. then i would'nt worry, but just for safety shut it off and get some leg excersize
DesertDog |
05-25-2008, 10:52 AM | #14 | |
RED How long is the wire to the Sensor on this gauge...Would you be able to mount it up on your handle bars and still mount the sensor on the motor? ALso what is the highest Temp it will read?
05-26-2008, 09:48 AM | #15 |
Different companies make then in different lengths. The Traxxas models like I posted are about a foot long, so you'd have to mount in down on the bodywork somewhere. Do a google search for "on board temp guage". I believe I have seen them with leads upwards of 18 inches long. That would be close!
