Old 05-27-2023, 12:24 PM   #1
kunudog   kunudog is offline
Templar X 250 brake a clutch lever replacement
Anyone know of a lever set that works with the Templar X? I bent my front brake lever pretty badly. I have tried Honda style aftermarket levers and those did not work.
Old 05-29-2023, 01:14 PM   #2
sshoress   sshoress is offline
sshoress's Avatar
https://a.co/d/gboh1dg
2023TEMPLAR X 6Sp <3 Central FL
  • Renthal oversized 1 1/8" FatBars, StickyGrips, Nibbi Throttle, Nibbi 30mm Carburetor, Nibbi Ignition, NGK Plug, RX Xring Chain, Upgraded sprockets for top end, 788 PowerCore2 Pro Tork Full Exhaust System, Shinko 7058s, Co1/Senge Graphics Kit, collapsable shifter, steel brake lines, EnjoyMFG Seat Cover, MSD spark wires, Dunlop barkbusters, aftermarket CDi, rear lights rewired under rear fender (clean now)
Old 05-29-2023, 10:35 PM   #3
TemplarM250   TemplarM250 is offline
TemplarM250's Avatar
I also dropped my bike on the trails and bent the front brake lever. I ordered a GPX TSE 250 front brake lever that should be an OE replacement. Has not shown up yet and cannot verify fitment. Did order another lever directly from Powersportsmax.
2022 Templar M 250
28 mm KIMISS carburetor 125 main 42 pilot Needle clip at center
DID x-ring chain JTR897 45 tooth rear sprocket
