Hawk 250 DLX Codes
where could I locate code descriptions for the DLX? specifically a p0118.
Obd codes are fairly universal. P0118 is a coolant temp sensor fault, which I can only assume is the head temp sensor on the engine.
thanks. just found this.
https://chinariders.net/showthread.php?t=15675 Says it's a problem with the cylinder head temp sensor. Looking at a bike which is cheap, but with problems. ![]() |
P0118 is usually triggered by the sensor voltage being too high, likely the result of an internal short from failure. Probably just needs a new sensor.
If he does, you know I have a Hawk that doesn't have any codes and would gladly hold it for you. lol
#7 | |
![]() Unfortunately, I missed the opportunity. he sold it already. :( |
Well that sucks. I've had that happen to me too many times. I've actually taken off work and told the guy I would be there In a few hours. I show up and he had just sold the bike. A phone call would of been nice instead of me taking a 2 hour round trip. Makes you want to throat punch someone.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-18-2023 at 10:57 AM. |
