05-15-2023, 09:22 AM | #1 |
Trailmaster TM35
Hello... New here.
I have a 2023 Trailmaster TM 35 coming in a week or so which has a YS - CB250F 5SPD motor and I am just wondering if anyone here has one and if anyone has done modifications to it. I am curious if the stock carburetor is decent, or should I go ahead and order one now. And if so, would a 28 mm be adequate or should I opt for a 30 mm. According to the website, it comes with a PE 28 carb from the factory. I have experience using Mikuni carbs only, but it seems here that a Nibbi carbs are a favorite. Any opinions on that are welcome. Secondly, does anyone have a recommendation for an exhaust for this or is the exhaust already decent to begin with? Thanks for any interest shown in my questions, and I'm open to whatever suggestions you guys may have. Thanks, Jason |
05-15-2023, 10:00 AM | #2 |
Welcome aboard! Ride it as is and give it time to break in before doing any mods. Being that it comes with a the Nibbi it might already be tuned.
05-15-2023, 01:18 PM | #3 | |
As for the exhaust, I am not aware of a direct replacement performance pipe. The best option seems to be to decat the oem pipe. GL
22 Templar 250 Last edited by Fast_Freddy; 05-30-2023 at 11:36 PM. |
05-30-2023, 04:11 PM | #4 |
Thanks. I got the bike and rode it for the first time today after going through the install process. I put a Nibbi 28mm carb with a 42 pilot and 112 main. So far so good with the pilot, I breaking it in so time will tell if the main is good.
The spark plug looks nice and tan and throttle response is good, so I'm thinking the pilot jet of 42 is a good size. The motor is the same as the Templar Pro , a ZS172FMM -3A Once I break in a little bit more I'll be able to test and see if 112 is a good mean or not. Anyone running this carb set up on this motor, what are you running for your main jet? I do have a question about setting valve clearances on this motor. I have experiences with the smaller YX piranha motors, but this is completely different. A write-up or video on how exactly to get in there and do the valves on this motor would be super helpful. It seems like there's not a lot of space to work in. Thanks for any assistance anyone can provide. Jason |
05-30-2023, 11:35 PM | #5 |
If you ride in Denver, CO that 112 main jet may not be too lean. Stock is 120, many of us are running 125 and I know a few running 130-140. I'm at ~300 ASL, most are between 100-2000' ASL. Thumper did a nice valve DIY guide you can find here. I recommend removing the seat and gas tank for easier access.
22 Templar 250 |
