Old 05-13-2023, 08:46 PM   #1
adb1779   adb1779 is offline
TBR7 stock air filter replacement - where to get it
Hi,
Does anyone know where to get a replacement for the stock air filter on a 2021 Toa TBR7?
It measures 5 3/8 by 4 1/2 inches and is about 3/4 of an inch thick. It is a regular pleated paper filter with a orange rubber like edging.
I have looked on the regular Tao sites but it is not listed. I imagine it matches some Honda filter but not sure which one.
Thanks
Old 05-14-2023, 08:34 PM   #2
buzz   buzz is offline
Yes i get mine on ebay ,Thinking xr125 honda. around 10-15 dollars
Old 05-22-2023, 11:00 PM   #3
Wix 49916 needs a thicker rubber base
Hi,
Thanks for the note about the Honda 125 filter. I tried a Wix #49916 which had close measurements but was not thick enough. I had to add foam tape to keep it in place under the plastic mount. It finally made good contact on the top and bottom to keep it from moving around. The pleat height is half of the original but I had to get it to work as the mice had their way with the original filter.
Al
Old 05-23-2023, 08:23 AM   #4
Captcj68chris@aol.   Captcj68chris@aol. is offline
Air filter
Hi, 2020 tbr7. I ordered green foam air filter material , A bulk size slab about 10 inches Square off eBay and cut it to match the original filter. A little oil on filter and grease where
It contacts the cage where it sits.
Christopher
Old 05-23-2023, 10:16 AM   #5
Foam Filter
Thanks for the foam filter idea. Since there are two supports in the opening that should be enough to keep the foam in place along with what is under the hold down on the edges.
Old 05-29-2023, 11:06 AM   #6
Honda dealer referenced this HiFlo replacement
Hi,
I went to a local Honda dealer, they came up with an OEM number of
17211-KRE-900 which they could not get but they found a HiFlo which replaced it HFA1127
http://www.hiflofiltro.com/catalogue/filter/HFA1127
Old 06-13-2023, 02:35 PM   #7
Found one on ebay in UK
This is where I found it
V FILTER FILTER, AIR Honda XR125L (03-07) 17211-KRE-900 compatible with HONDA XR
From seller : sobreruedas-spain (51235)
Ebay URL:https://www.ebay.com/itm/20288429918...&segname=12052
Old 06-13-2023, 08:48 PM   #8
Ebay has them ,i have 5 of them.
