04-19-2023, 01:02 AM | #1 |
Miles or Kilometers??
This may sound silly, but my new Brozz 250 has an odometer graduated in kilometers and I see lots of Brozz owners on here speaking in terms of miles for service intervals. Are y'all making the conversion or is this being used interchangeably??
Sincerely, Jakius (I'm new )
'22 Brozz 250 Recon |
04-19-2023, 05:18 PM | #2 |
I also may be mistaken...
04-19-2023, 06:01 PM | #3 |
Everyone who claims to be getting to 100mph has the kph speedometer... and no knowledge of what a kilometer is.
04-19-2023, 07:23 PM | #4 |
Most China bikes ship with digital speedometers and set by default to KPH as this is used in most of the world. You can easily change them over to MPH using some combination of button pressing or holding a button down. I don’t know the Brozz Recon method as I don’t own the bike but someone that owns one might be able to tell you how it’s done if it can be done. That or just contact the company selling them and ask them what you need to do to switch the digital speedometer over to MPH.
