need help with my bashan
need help finding bashan bs250s-11b starter gear cover. if anyone know where to buy it or has one that he doesnt use then please help a fellow rider out.
Where are you located? I don't think i ever seen one available in the US. https://www.ud-spareparts.com/Bashan...5_564_565.html
on the website its out of stock and im located in estonia
You can get it from the UK;
https://orangeimports.co.uk/products...13966311653439 Edit - Oops, that site shows it's sold out also. Sorry. Is the cover you have damaged?
Looks like this one from VMC might fit. Outside looks a bit different but the inside looks the same. VMC says it fits a Lifan motor. You may have luck searching for it that way.
https://www.vmcchineseparts.com/prod...ar-cover-cg200
