Old 04-04-2023, 07:10 PM   #1
FL-KPM   FL-KPM is offline
New bike…bad bearings
So just got a little under 200 miles on the new kpm. Riding home from work tonight I start hearing a scraping noise. Thought maybe caliper was dragging a little. So I got home and put it up on a stand and sun the rear wheel and I could clearly see the pads were not rubbing on the rotor. My guess is that that rear bearings are going out already. I’ve replaced bearings before on shaft driven bikes but not on sprocket driven bikes. Anything to look out for? Advice? And does anyone happen to have a couple of bearing numbers? Tried the search function but no luck on the kpm or the kpr as far as info.
Thanks
Old 04-05-2023, 08:03 AM   #2
Contact American Lifan or the dealer you bought it from. Lifan has a 2 year/12,000 mile part warranty.
2004 Honda ST 1300
Old 04-05-2023, 10:56 AM   #3
Yeah, I bought it. At Denham motorsport it has a 12,000 mile warranty. I really didn’t want to put the same bearings back in.. I guess that I will wait till I get the new bearings from them and see if I can cross reference better bearing
Old 04-05-2023, 01:43 PM   #4
dirtbkr188   dirtbkr188 is online now
dirtbkr188's Avatar
With the bike up on the stand, did you try to shake the wheel back and forth, to see if there is any side play or slop?
Old 04-05-2023, 08:45 PM   #5
I did put it in a stand, no play or slop yet. But I can hear them noise coming from the hub. Also verified that the pads are not rubbing the rear rotor.
I believe it is in early stage of failure, of i kept riding it I’m sure it would develop play in the rear wheel.
Old 04-25-2023, 08:18 AM   #6
buzz   buzz is offline
You sure would,replace with a good bearing. I would do both wheels.
