Old 03-26-2023, 09:23 AM   #1
BakedOregonian   BakedOregonian is offline
No choke = Kill switch
My Hawk idles great until I close the choke all the way then it immediately dies? Is this an adjustment issue or possibly a dirty carb?
Old 03-26-2023, 10:18 AM   #2
It sounds like you are too lean. Increase pilot jet size. You can also adjust the airmix screw, but it sounds like you need a bigger jet first.
-NOS 2020 KTM 250SX (2-stroke motocross)
Old 03-26-2023, 10:52 AM   #3
buzz   buzz is offline
Try adjusting idle screw,just a little at a time, Thumper has a good point,maybe iean. I have a TBR7 that has to be adjusted all of the time,not a big deal. When cold has to be adjusted higher, after warm up adjust back down. Hope this helps.
