Old 03-22-2023, 10:47 AM   #1
N7sithis   N7sithis is offline
N7sithis's Avatar
Flashing brake light issue
I put LEDS all the way around, flashers and headlight work fine but the brake light is on drugs.
Rear bulb is a LED flasher (Flashes 3 times then acts as normal brake light)
If I turn the ignition on but don't start the bike the brake lights work as intended (AKA they flash 3 times then stay solid when holding either brake)
However, if I Start the engine and pull the brake lever with the bike running (either brake) the brake light just flashes continuously.
I have an upgraded battery if that matters, not sure what could be causing this issue? Any ideas?
Edit: Brake light works correctly with headlight/run lights turned on?
brake, flashing, led, light, rear
