03-11-2023, 07:20 PM | #1 |
PSA: Fuel Deception at the shared Pump
Other than people putting premium priced fuel in non premium engines (premium price, not premium quality, higher octane in premium damages the gasoline's ability to combust and retards it; there is nothing premium about premium gasoline, all the premium performance is in the high compression engine design that needs damaged gas to run properly) you also get screwed at pumps that shares a nozzle, especially if you are only pumping a gallon or fuel container worth.
