PSA: Lose the chin curtain and Gain less CO2
It's winter! I need that limited air flow but it's somewhat self limiting because if I'm riding slow or stopped I have to raise the visor a bit to keep from fogging up. Still it is interesting.
I actually modified mine on my Bell helmet. I had a friend sew in a mesh fabric so it provided a bit more airflow without increasing the noise level too much.
My chin curtain is a mesh fabric.
