Old 01-26-2023, 10:29 AM   #1
4T_Goblin   4T_Goblin is offline
4T_Goblin's Avatar
Vader Headlight swap to Harley 5.75" LED
Hi all -
I am changing my headlight assembly out for a round light LED. According to similar items it has 65w high-beam and 35-45w running/low-beam. Ironic that the model I picked doesn't have its tech specs listed. I pulled these numbers from similar listings.
This headlight comes with adapters that do not match the Vader harness, so some re-wiring is in store. I'm researching now whether or not I would need a relay for this headlamp with such a low draw.
at 65w high-beam at 12v draws 5.42 amps so I'll have a 5a fuse in line to the high-beam ??
I am familiar with changing plugs and wiring but I am not sure when to use relays.
2020 Vader X-Pro X-7
2019 Kawasaki Ninja ex400
2022 Lifan KPX 250
Old 01-27-2023, 08:54 AM   #2
4T_Goblin's Avatar
I successfully rigged the headlight up using the stock harness by changing the connector on the headlight. It works fine with KOnEOff and KOnEOn. I have not ridden it to test how the beam looks on the road.
I still plan on installing a relay, as I now understand what its purpose is; a remote switch to take the load off the actual switch. I do not know the true wattage of the headlight, but it couldn't hurt to be safe.
2022 Lifan KPX 250
Old 01-27-2023, 10:52 PM   #3
4T_Goblin's Avatar
https://youtube.com/shorts/ziw_320T10s?feature=share
Here it is on the stock harness
2022 Lifan KPX 250
