Old 01-19-2023, 06:39 PM   #1
vader125   vader125 is offline
how to turn off boom vader 125 running light?
How can you turn off or disconnect the daytime running light on a 2021 Boom Vader BD125-10?
Old 01-20-2023, 04:33 AM   #2
4T_Goblin   4T_Goblin is offline
4T_Goblin's Avatar
Try the Control switch below the kill switch on your right side
2020 Vader X-Pro X-7
2019 Kawasaki Ninja ex400
2022 Lifan KPX 250
Old 01-20-2023, 11:45 AM   #3
The switch only turns the tail light on and off, and the high beam turns on and off with the headlight switch, the running light/low beam headlight always stays on.
Old 01-21-2023, 02:34 PM   #4
If anyone has a wiring diagram for the Boom Vader BD125-10 that would help aswell, all help is appreciated. Thanks
Old 01-22-2023, 12:20 PM   #5
Deckard_Cain   Deckard_Cain is offline
The closest I've ever found was for the SSR Razkull.
http://www.ssrmotorsports.com/store/...%20Diagram.pdf
Old 01-22-2023, 01:12 PM   #6
Thanks, yeah it seems like it would be close only thing is the Vader has 2 bulbs for the headlight instead of 3 like the Razkull, on the Vader the daytime running light is the low beam headlight.
Old 01-26-2023, 09:38 AM   #7
If it were me, and I've already changed out my Vader headlight for a round one anyhow, but I'd simply put a toggle switch inline with the power to the Low Beam headlight- in which case that would act as a master headlight control switch, and the existing one only activates the high beam and taillight.
Old 01-26-2023, 02:29 PM   #8
Bruces   Bruces is offline
I would switch the ground instead of the power with a good quality toggle switch .Can I ask why you want no headlight ? Seems to me your bike is so small your asking to get run over
Old 01-27-2023, 12:07 AM   #9
That is what I was actually thinking, seems like that’s the only way to make it turn on and off.
Old 01-27-2023, 12:18 AM   #10
I’m going to have to take it apart to see what’s the best way to put a switch, and I do want the headlight… I would just like to control it completely on and off like you normally would on most vehicles. It would be the same, the only difference is that it would have a switch…
Old 01-28-2023, 10:50 AM   #11
Sorry, caught this a little late; contact Pete at Kronik Racing as he is the Vader guru and sells a bunch of them. https://www.kronikracing.com/
Old 01-28-2023, 01:10 PM   #12
4T_Goblin's Avatar
There is a yellow wire with a bullet connector coming from the control harness that is power for the headlights. you could introduce a switch in line there.
2022 Lifan KPX 250
Old 01-28-2023, 04:31 PM   #13
krat   krat is offline
Not that it seems to matter much, but you guys are talking about how to disconnect a safety feature that is mandatory for licensing and road use in every state since 1977.
Not to mention that old "they said they did not see me and pulled right out in front of me!" accusation so often heard.
%90 of the Chinese motorbikes ever made are still on the road. The other %10 made it back home.
Old 01-31-2023, 09:52 AM   #14
Not in the U.S... DRL's are still not compulsory, otherwise all older vehicles would require to be retrofitted.
Now, running lights in general, that's different.
I don't agree with disabling the lighting either.. I want MORE light, not less. But if the OP wants to risk getting turned into a bloody pancake mixed with chunky human salsa, that's on him.
Old 02-01-2023, 04:19 AM   #15
Thanks for your help, when I get around to it this seems like it should do the trick.
