Templar fork preload spacers
Has anyone done this yet? I believe my Templar is sprung for a ~150 lb rider and I weigh 250 lbs. I adjusted the rear shock preload but I think I need at least 10mm spacers in the forks.
I've seen Joe Henner's videos for KKE and SZC fork spacers but don't know which (if either) applies to the Templar. I would have opened up the forks by now but it's cold here. If no one knows yet I'll post some pics when I open my forks. TIA
22 Templar 250 |
Another question gents: Has anyone changed fork oil in their Templar forks and if so, what weight oil did you use? Alternatively, does anyone know the weight of the oem fork oil? I like the damping rate in my forks but the spring is too soft. Since I may have to live with these soft springs I'd like to see how much I can improve the forks with heavier/more fork oil. Any recommendations are welcome and appreciated. TIA
22 Templar 250 |
Subscribed as I too am around the same weight.
Templar X 250 Yamaha XSR900 Kawasaki Brute Force 750 Yamaha TT-R 50 |
See inside the forks here. Not sure if/where shims might go.
Links to posts in the Temp X thread with FRONT FORK service videos. I recommend a good 15W fork oil like Motul. This will stiffen the fork, improve performance and bring the adjustable range closer to the middle of the "click" range. https://www.chinariders.net/showpost...&postcount=545 https://www.chinariders.net/showpost...&postcount=546 https://www.chinariders.net/showpost...&postcount=549
Under the spring at the bottom seems like the best place to me. What a horrific process though. Disassemble the entire fork to add/remove preload
#6 | |
Perhaps I should start off by adding more oil to stiffen them up a little by reducing the air volume. At least that should reduce the bottoming out and nose dive. TBH I'm just not sure about 15W and these USD forks are a PITA to change oil. I might be happier with 10W but who really knows? Below are some links to some relevant Joe Henner fork videos. Wish I knew who makes these forks? KKE SZC
22 Templar 250 |
On the bright side, spring preload should be a one time job. At least for my use it will be good enough. The old damper rod forks sure were a lot easier to work with.
22 Templar 250 |
My front forks and rear shock are KKE on the X model. The logo is on the cap. The small shims that Joe Henner put under the retaining washer on the top seems like a great way to introduce preload. And you don't even have to remove the fork tubes.
That is a pretty simple procedure. You might want 20mm instead of 10. Buy as set of those from Joe. If they work, you are done. Or you can find a machinist to make them with 20mm length. FYI- I have upside down forks on the Storm. I switched to Motul Expert 15W medium/heavy. The front end stopped bottoming out. I like the stiffer forks too. Changing the oil isn't bad. You do need to remove them, but just pour it out and refill. If you do all of that, then placing shims under the spring (as Dan suggests) wouldn't be much more work.
#9 | |
I also ordered a liter of Motul 15w fork oil. I double-checked my forks for identification and sure enough, right there on the caps, plain as day, "KKE". I know I've seen that before! Another senior moment... now what were we talking about?
22 Templar 250 |
#10 |
I heard back from Joe Henner and ordered my preload spacers today for $30. I'll try to take pics of the installation and a review.
I also added 10ml of power steering fluid to each fork today (PSF was the only hydraulic fluid I had laying around). I'm going to add 10ml at a time until I find the level I like and then replace it with the same volume of 15w oil.
22 Templar 250 |
#12 |
I finally got the spacers and 15W fork oil installed and Wow! Night and day difference! Reducing the front sag has made a noticeable improvement in steering & stability and greatly reduced nose dive. I haven't ridden it enough to comment on the fork oil because I've been sick but my initial impression is positive.
I should have taken some photos but I forgot. It's pretty self explanatory once you get the fork caps off. Joe Henner told me there is even a video on Youtube but I couldn't find it.
22 Templar 250 |
#13 | |
#14 | |
I think you'll like the change with 15w oil. If you still need more preload you can add Henner's slotted spacers without removing the forks. Just remove handlebars and fork caps. GL and post back with your results or any questions.
22 Templar 250 |
#15 |
I changed my fork oil to 15w. Procedure was very simple. I measured 260 ml in each fork but that was with a kitchen measuring cup. I put back in a tad more. I think there is more stiffness but it’s not night and day. The rebound still seems violent. If the wheel gets in the air the shocks extend back down with a bang. That may be normal for a dirt bike but I have nothing to compare to. This is my first dirt bike. I ride on and off road with 15lbs of air front and back. Is there anyway to slow down the rebound??
