Old 01-04-2023, 04:00 PM   #1
Hap   Hap is offline
How many links are in the stock Templar X 250 chain?
I’m sure the answer to this question is probably in the forum somewhere. But I can’t find it. Thanks.
22 Templar X 250
Hand Guards
Custom Graphics
Pro Taper Grips
125 main 45 pilot jets
42 tooth rear sprocket
2010 Yamaha Vstar 1100 Silver Star
Old 01-04-2023, 04:19 PM   #2
I actually never counted mine, I replaced mine with a 120 link, removed I am guessing 5 or 6 when fitting for my smaller rear sprocket.
Old 01-05-2023, 08:14 AM   #3
Hap   Hap is offline
Got home yesterday and counted mine. 114 links in the stock chain. Does different chain lengths wear the sprocket more than others? I never really considered this until now. Thank you TP for your response. Always helpful.
22 Templar X 250
Hand Guards
Custom Graphics
Pro Taper Grips
Old 01-05-2023, 08:52 AM   #4
TominMO   TominMO is offline
You have to pick the right chain length (or remove links on a longer chain) so that you can adjust it and have room for it to go back as it stretches. If you buy a longer chain like a 120 link, put it on and see how much you need to remove. Make sure to have the axle near the front of the adjustment slot when you do this, to give room for stretch.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle.
Old 01-05-2023, 07:35 PM   #5
Not enough to be noticeable to the average rider reading the forum but you are changing the overall wheelbase and moving the weight balance of the rider with respect the rear wheel a fractional amount when the rear is adjusted at either end of the adjustment range. The sprocket sizes determines the wear rate with the two sprocket system such that the smaller sprockets teeth make more chain contact per tooth than a tooth on the larger sprocket. Hence if you had a perfect three times number of teeth difference the smaller number of teeth sprocket wears three times faster than the larger sprocket. With new chains you normally want new sprockets installed at the same time as worn sprockets and new chains are going to be a bad mix wearing the new chain faster. I had about ten miles on the bike when I changed the chain and rear sprocket so I kept the small oem sprocket on the bike. Other than running a new chain on worn sprockets, the conditions where a chain is ridden in has more of an impact on wear, dirt and sand being more wearing to a chain than street riding. Keeping it cleaned and lubed will be enough for most riders to get good life while keeping an eye on sprocket wear. Everyone has their favorite chain method for care so I’m not recommending any products but for the curious I have no lube right now as I’ve checked all my local physical stores and none have the one I use, so I’ll put an order on Amazon for mine as it’s there.
