More Stability?
Has anyone had any luck making their ds more stable at higher speeds? Tires, steering damper, etc...
2005 ROKETA/GOLDEVALE DB-07 200 K&N filter (ebay), Drilled exhaust (me), Biike LCD Speedo (ebay), clip mod (me oh my what a difference that made lol), 15t front 40t rear sprockets (Bruce @ EJcycles hes the man!!) top speed 74 Street Legal!! |
#2 | |
Re: More Stability?
Changing to street tires will help some too. I really noticed a difference after switching out the front tire.
These things are just not heavy enough for that speed, but I still do it. Allen
My bike had really loose steering head when it came out of the crate. The handling felt wierd, until I tightened the steering head up. Now, I feel my bike is stable even at 80 MPH.
Chinabikeless |
cool i will try those thanx
Yeah usually the front tire will be alot flatter(less knobage) if its DOT, the rear one too....helps with steering for sure, I agree these bikes are pretty slick with the steering when you first get them.......
My gy5 was great, the gy6 gets a bit of a speed wobble at about 105 to 110 or so.
You guys talking in kilometers?
I've only really gotten my bike up to about 55mph, and it rides fine and smooth. The only problem I have, like I metioned before, is right in the middle of maxing out on fifth gear, I have this loud buzzing noise, then it goes away. Can't figure it out though. Oh also, this may be off the subject of high speeds, but I found the source of my constant low buzz. It wasn't annoying, but it sounds way better without it. I noticed a bolt about 8" that goes through the bottom of the motor that was missing the nut to tighten it. I'll have to replace the nut, but without it, the bolt would just rattle like crazy. Glad I noticed it.
Not All Those Who Wander Are Lost |
Yeah I was talking in KM's... Glad you found the issue with that buzz, good to keep an eye on the motor mount bolts.
#10 |
im using mph with my new sprocket I can hit 70 mph. I think the stock tires are the biggest source of my wobble. Will replace with more of a street tire when I can. Thanx guys
#11 |
Your rims might not be perfectly round? Prop the front end up and spin the tire. Look at the distance between the ground and the bottom of the tire. Does that gap vary as the tire spins? It's usually more of a problem at slower speeds and goes away at higher speeds but you never know?
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
#12 |
Mav, do a search on the motor mounting bolts.
Those are the biggest source of vibes with these bikes. Put it on your to do list. The bolts are not very expensive. Allen
#13 |
Alright, sure thing. Um, what I described isn't the swingarm bolt, is it? And yeah, I live with my mom and she doesn't have any tools so as soon as I get the chance I'm going to take the bike to my mom's ex-husband's house and do a full out inspection. After that I'll just head over to my local hardware store and replace the faulties.
However, I still haven't found the source of my brief high speed buzz?
#14 | |
