Old 12-05-2022, 10:22 PM   #1
holi66   holi66 is offline
Apollo 250RX front axle size?
I just purchased a 2020 250RX that has had a rough life in its short existance. I am ordering various parts that need replacing and the one I'm stuck on is the front axle. I thought that the front bearings were bad, but no, lo and behold, the previous owner had replaced the front axle with a carriage bolt (seriously) of similar length but way under-sized diameter wise. (With that, I'm sure that I'll need new bearings now anyway.) I've searched online and I can't find the size (diameter and length) of the correct axle...and what spacers are needed. Any help would be much appreciated.
Old 12-08-2022, 07:48 PM   #2
found it...
In case anyone else needs to know, it's 12mm diameter x 220mm length (bolt shoulder to end of threads)
