11-20-2022, 07:23 AM | #1 |
New to the Chinese bikes
New guy from North Carolina just got my first 2018 bashan the guy I got it from said it’s a brozz but I’ve also been told it’s a raven. How can I tell what it is? There is no stickers on it. It also looks like it has Hawk 250 speedometer on it.
11-20-2022, 08:29 AM | #2 |
Motocheez had a page on each of them with a video and upgrades he has done over the years, you can see the assembly video for each and see if those parts you are seeing can be found on yours to identify what you have.
Raven: https://www.motocheez.com/vitacci-raven-250 Brozz: https://www.motocheez.com/brozz-250
11-20-2022, 08:54 AM | #3 |
What is on the title?
11-20-2022, 09:24 AM | #4 |
Only thing on title says bashan.
11-20-2022, 09:58 AM | #5 |
The Brozz has the counter balance engine and the Raven doesn't. Look for the big hump on the front of the engine
11-20-2022, 10:00 AM | #6 |
Ok will do.
11-20-2022, 10:03 AM | #7 | |
11-20-2022, 10:05 AM | #8 |
It’s a Raven from the look of the engine. Thanks JerryHawk250
11-24-2022, 09:13 AM | #9 |
Welcome! I'm from Lowell, NC.
11-24-2022, 09:28 AM | #10 |
One of the greatest movies of all time! Abby Normal?
