I have read several threads on carbs and am more confused then ever. There is Mikuni, Nibbi, and on and on. I don't have a hundred dollars to throw at a carb and then add even more money to modify it. I read where some have purchased carbs and ordered Jets that don't work. Jets made for old style carbs that don't work in new style.
Here is the thing, I have a 2022 Tao Rhino 250, I replaced the stock sprockets and Cain with the 11 x 37t set. I now want to replace the carb with the best size for my machine and get the correct Jets the first time. Please stear me to what I need. Thank you very much. |
I used this carb Mikuni Clone.... took the choke connector off the stock and placed on this one......
https://www.amazon.com/FI-parts-Miku.../dp/B07F387YWP Using jets: 30 pilot, 115 main, 4th notch down on needle GENUINE Mikuni pilot jet size 30 (VM28/486) https://www.jetsrus.com/a_jets_by_ca...-486_pilot.htm GENUINE Mikuni main jet size 115 (N100.604) https://www.jetsrus.com/a_jets_by_ca...arge_round.htm It's been some time since I purchased this. Get the carb... take the jet out and compare to the site.... if it looks the same then order up. |
I have the stock carb on mine but upped the main jet size a little when I went to a pod filter. Over 2000 hours on it that way and it runs great. Spark plug color is just right.
Thank you both for the great information. I have ordered the carb. and it will be here today. I am still breaking this thing in. It o ly has, mYbe two hours on it.
Problem that I am having now is that I had the transmission lock up in 3 or 4 yesterday and it took forever to get it unlocked. Hope this is not a sign of bad things to come. Any advice in this area would be greatly appreciated. Have a great Thanksgiving. |
Change the oil. The oil that came with it is mostly just for shipping. Clean the screen when changing the oil also.
It will get better when its broken in. Good luck
