11-19-2022, 08:47 AM | #2 | |
11-22-2022, 08:48 PM | #3 | |
How much air pressure do you run in that? |
11-23-2022, 07:50 AM | #4 |
This tire grips like superglue on the rim. Just make sure the rim is clean, no oil or soap residue when you mount the tire. Even without rimlocks, I can drop the pressure to below 20psi without worrying about shredding the tube. It is a stiff tire. But I generally run higher than that. It depends on the conditions.
