11-09-2022, 02:51 PM | #1 |
Introduction
Hello!
I recently bought a Brozz 250 Recon. I was impressed both by reviews of the bike and of peace sports support in case anything goes wrong. I'll be sure and update y'all with how the build goes when I get the time! I'm looking forward to all the small fixes that come with buying a crate bike from China. All advice is appreciated! |
11-09-2022, 02:55 PM | #2 |
Welcome aboard! Congrats on the new bike.
11-10-2022, 09:17 AM | #3 |
Hello and welcome, the Brozz is a good bike and very easy to work on. There are plenty of upgrades and accessories available, plus it’s super reliable. Peace sports is a good dealer and has a full supply of parts and some support videos as well. Which is why I bought my Brozz from them as my first China bike. I didn’t have any negative experience with the bike and the resale was pretty decent.
11-10-2022, 01:38 PM | #4 | |
Jeff's upgrade version of the Recon is probably the best dual sport adaptation of the counterbalanced 229cc ZS167FMM available today. NICE choice!!
I have a Bashan Storm. Same engine, many identical component (smaller wheels, and I had to buy knobbies to replace the squirrely dual sport tires) Some people will tell you that you should get a new carb, but frankly, the stock You-all carb just needs slightly bigger main and pilot jet, unless you are at higher altitude (over 4500ft or so). Maybe a 1mm needle shim as well. For about $15, you might get a roller style throttle. It gives you more fine throttle control, and much less twist resistance. Before install, hang it straight (gravity) and spray silicon lube in there. Quote:
Tags |
brozz, brozz recon, introduction |
