Old 10-31-2022, 02:09 PM   #1
C_Geezy   C_Geezy is offline
Gasoline leaking out of my bike after starting(from carb) any advice? (Pics attached)
I started my bike this weekend and saw gasoline dripping out of it. I gave it a quick ride to the store and it wouldn't start on the way back, anyone every had gasoline leaking from there carb? (Pics Attached)
Old 10-31-2022, 03:44 PM   #2
clash 168cc   clash 168cc is offline
Float sticking. Tap on carb. See if it stops or clean carb.
Old 10-31-2022, 04:07 PM   #3
As Jeffery stated. Tighten the bowel drain screw. It probably vibrated loose.
2004 Honda ST 1300
Old 11-02-2022, 10:00 PM   #4
Muskoka Dual Sport   Muskoka Dual Sport is offline
I had the same problem on my 250 and it was the float was set too high. Lots of good videos on youtube on how to set a float but basicaly you take tha carb off remove the bowl, turn it sideways and adjust the float tab untill the line on the float is in line with the bottom of the carb.
heres a good video, hope this helps CHEERS!!!
