10-24-2022, 04:24 PM | #1 |
progcdi
hi folks,
i found an interesting programable cdi on the web.. bus digit progcdi: it a black box with orange lettera and a couple 2led digit.. could be programed in many aspect without a pc.. but to set the advance needs an info.. someone knows this value : “In "Pu" introduces a physical position of the crankshaft position sensor. This is the angle between the pulse from the sensor and the upper position of the piston. This is normally from 20 to 30 degrees.” ????? Engine is a 169fmm |
10-25-2022, 09:02 AM | #2 | |
I googled "bus digit progcdi" and got nothing
Got a link or character string from the post/ad "on the web"? Quote:
10-25-2022, 02:51 PM | #3 |
10-26-2022, 02:43 PM | #4 |
Pu is the pick up position in degree..you must measure with degree wheel how many degree before tdc the thoot on the flywheel meets the pick up ....it s called the static advance
