Old 10-15-2022, 04:39 AM   #1
Dustoff42   Dustoff42 is offline
Kpr 200 Engine Ticking
So I have about 80 miles on this bike now and I noticed this sound coming from the engine. Has anyone heard this noise with this bike before? Does not sound normal. I am about to change the oil out and put a new oil filter in since I didn’t change the original since I got the bike. Though I did drain the original oil. https://youtube.com/shorts/RrqLAHPRCI4?feature=share
Old 10-15-2022, 08:44 AM   #2
Change the oil, adjust the valves. It does sound loud. You sure you don't have an exhaust leak.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 10-15-2022, 09:53 AM   #3
herbie   herbie is offline
I agree with what Jerry said. My engine has always sounded a little noisier than some other bikes I've owned but it has not ever been a problem. The camera may be amplifying the noise some but adjusting the valves and doing a complete oil change is a wise thing to do. I love the green color by the way!
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 10-15-2022, 11:11 AM   #4
clash 168cc   clash 168cc is offline
I can hear the valves tapping. Mine has a Lifan GY6 type, different engine though. It also started tapping early on. Adjust the valves by the plate on the engine. Use synthetic. See if it sounds normal again.
Old 10-15-2022, 05:38 PM   #5
Falkon45   Falkon45 is offline
Falkon45's Avatar
Did you put enough oil in? Mine was noisy like that when I ran low.
Old 10-15-2022, 09:21 PM   #6
How would I tell if there is an exhaust leak? The exhaust pipe seems to heat up pretty wild towards the middle. And would you recommend doing the oil change first or the valve adjustment?
Old 10-15-2022, 11:25 PM   #7
TominMO   TominMO is offline
Since you did change out the Chinese mystery oil, I'd just make sure the level is correct, then check out the valves. If it was low on oil, add what you need and run it again. If the sound goes away, it was the oil level. If you still have the sound, wait for the motor to cool down overnight and then check the valve clearances.
Personally I think it's very loose valves. Even if the sound goes away when you add oil, you really should check out the valves, on general principles.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle.
Old 10-16-2022, 08:25 AM   #8
So I did the valve adjustment and it still does that ticking noise. But now something interesting has happened. Something shot out of the exhaust! Looks like old oil but not sure. Uploaded another video to show the sound still and the stuff that came out. https://youtube.com/shorts/dsG8RZS5jX8?feature=share
Old 10-16-2022, 02:00 PM   #9
J4Fun   J4Fun is offline
Seems like that oil on the floor is fresh by its color. Is it possible that the engine is now over filled. It didn’t come from the exhaust, more likely a crank case breather. Just my thoughts!
Old 10-16-2022, 04:17 PM   #10
Haha thank you. I like it also. So I adjusted the valves and started the engine and this stuff came out the exhaust. Hard to tel if it is gasoline or oil t it seems weird. You ever seen something like this after a valve adjustment? Might have to much oil in there tbh. Need to do the oil change still.
Old 10-16-2022, 06:05 PM   #11
Hello Dustoff, that looks more like rusty water to me, there is a drain hole in the bottom of the exhaust to allow condensation and water from rain or washing the bike that gets into the hole of the muffler to drain out. If you notice the drain hole at the bottom of the exhaust is all rusty. That's most likely perfectly normal. You can watch my oil change video if you would like to see how everything goes. Be sure when you check the oil level both now with the old oil and after the oil and filter change with the bike perfectly level, (It does make a difference) If you have any questions don't hesitate to ask
1978 Kawasaki KL250
Old 10-16-2022, 07:51 PM   #12
Ya that’s where the stuff shoots out from. I did ride in the rain a little but it was a drizzle at most. I wonder why it’s in there. I’m going to double check my gaskets on the engine where I adjusted the valves just in case. Did you ever notice yours not seeming to use the coolant? It seems like mine hasn’t gone down much. I love this bike tho. I have been taking it to work as much as I can. Just want to make sure I have everything running right. Want this to last.
Old 10-17-2022, 04:38 AM   #13
You still have the catalytic convertor in yours and it will have some condensation coming out as a result, the same as you see happening on automobiles. When I said something about riding in the rain, what I meant was going from one place to another and stopping and it is cooling off and some unintentional rain drips inside. If you're riding it and not stopping, the hot exhaust and exhaust pressure won't allow much water to make it very far at all so it wouldn't be a problem, but even still it will drain out if it does. Washing the bike is when you can get some water down into the exhaust, but that drain hole will allow it to come out without any problem. As far as loosing coolant, I have topped mine off once since I've had it, but not since. You shouldn't have to add coolant once it's full but it's always good practice to check the level once in a while when you have the rear seat off, coolant leaks can and do happen.
1978 Kawasaki KL250
Old 10-17-2022, 02:19 PM   #14
Thank your amazing. Did the oil change and adjusted the valves once more because I’m neurotic. The oil filter was dark and the metal mesh screen had metal flakes in it. Chinese oil man. Didn’t clean those out when I put the last new oil in. Bikes running and sounds great so far after everything was done. The ticking is there still but I’m pretty sure it’s the fuel injector and solenoid going off and on. Pretty consistent with acceleration and doesn’t get louder or after. Tho is better after new oil and valve clearance. Got wrong spark plug so need new one of those for the bike. Im sure that will help it even more.
Old 10-17-2022, 03:58 PM   #15
JimS   JimS is offline
Great group of guys here with lots of knowledge and always willing to help. Pay the few extra bucks and get the NGK Iridium plug.
engine, kpr 200, kpr200, ticking
