Old 10-15-2022, 03:29 AM   #1
miraclepieco   miraclepieco is offline
Push-lock Gas Cap Leaking
Push-lock type gas cap (as pictured) leaks when the tank is full. Can't tell if it's coming past the gasket or through the vent system. Has anyone experienced this? How do I fix it? I'd rather not replace the cap cuz it's keyed to my ignition. Is the gasket replaceable? THANKS!
Old 10-15-2022, 07:00 AM   #2
Mine does too. You can't fill it that high. Common thing. Even other bikes.
Old 10-15-2022, 09:38 AM   #3
herbie   herbie is offline
I had the same problem with my 2018 Brozz which is the Storms brother. Check out this thread, a new cap fixed it completely. I know you didn't want to replace it because of the key but I just carried 2 keys, not a big deal to me but it's your choice.
http://www.chinariders.net/showthread.php?t=23990
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 10-15-2022, 10:21 AM   #4
cycleway4   cycleway4 is offline
yes,...the Honda cap is an easy fix....I posted this in 2020........."I went with the Honda OEM as soon as I got my bike,...has never leaked,...it is an IDENTICAL twin of the original cap (except of course for the quality,..where it is all Honda there..)"
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 10-15-2022, 10:51 AM   #5
My thread on the Brozz is from 2019 and your right it was the perfect fix. I never had another problem with it after that. Fortunately the Brozz had a gas cap redo in 2020 I think it was. The new flip up design was much better
1978 Kawasaki KL250
Old 10-16-2022, 01:39 AM   #6
Wow, in those threads is EVERYTHING I needed to know about a leaky gas cap! Thank you gentlemen!
Old 10-17-2022, 10:36 PM   #7
Follow-up report:
Of the multiple solutions to this problem from herbie's thread, the quickest, easiest, and cheapest, was to cut the bottom off the fuel cap mechanism. If it doesn't work, I can always buy one of the Honda replacement caps, right (yikes, they're up to nearly $60 now!)?
Upon cutting the bottom off the cap, I located what may have been my leakage problem: a dried and broken o-ring that seals the breather mechanism to the cap.
The great thing about cutting the bottom off the cap is that now the breather hole is well up inside the mechanism where it should be shielded from slopping gas. And it makes the cap about an inch shorter, allowing me to fill the gas tank one inch deeper.
Just a note: If you're considering doing this, keep the cut about 1/8" (3mm) below the locking ears or you could cut into the locking mechanism.
But did it work? I don't know yet; I haven't road-tested it.
