10-12-2022, 01:43 PM | #1 |
2022 Brozz Recon wont run without choke.
Just got a new 2022 Brozz 250 Recon and it will not start up without choke even when warm. In addition it will not stay running without about a 1/4 choke and dies instantly with no choke. Curious where to start with this and would love some suggestions from you all.
Also when it is on half choke it revs really high. |
10-12-2022, 02:02 PM | #2 |
I would check for intake leaks.
10-12-2022, 03:57 PM | #3 |
Yeah, intake leaks or one of the passages in the carb is blocked with debris
