Old 09-25-2022, 04:43 PM   #1
nickelghandi   nickelghandi is offline
2022 KPR 200 Idle and Throttle Issue
Hi all,
I am new to the forum. I have a 2022 Lifan KPR 200 that I just got. It starts fine and will usually idle, but it hunts in RPMs and occasionally stalls. It doesn't seem to matter if it's hot or cold outside or if the bike is warm or not.
If the bike is at idle and in neutral or has the clutch in and I twist the throttle a bit, the bike dies. I have to very gingerly turn the throttle and get the RPMs up to about 2-2.5K before it will properly rev. I am currently working with the seller but progress is very slow. If anyone has any clue what the issue could be, please post or shoot me a PM. Video is below.
It's fixed! Check the new video for the procedure:
Old 09-26-2022, 07:17 AM   #2
herbie   herbie is offline
I would check the intake to make sure everything is tight. But I would do the basics first, check valve clearance and check spark plug gap or replace the plug to make sure the engine is able to run good. If it’s still having a problem after that at least you know that part is good.
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 09-26-2022, 01:10 PM   #3
JimS   JimS is offline
Also check all of the electrical connections on the engine to make sure they are fully seated and there are no bent pins. Being ECU controlled, a bad or missing input from any one of the sensors could cause issues that may or may not trigger the check engine light.
Is your radiator full of coolant?
Old 09-26-2022, 04:05 PM   #4
Thanks for the suggestions guys. Last night I pulled off the right panel and checked over the intake and EFI parts again. Then I tried unplugging things one by one and starting the bike. Unplugging the sensor pictured here seems to improve the running of the bike tremendously. It idles smoother and I can turn it to 1/3 throttle from idle without it dying.
My guess would be that it is the MAP sensor? It connects to a short hose that connects directly to the intake manifold. The only other connection to it is the electrical connection.
File Type: jpeg 8CB4A38C-9FA2-4F1C-8C4B-728E594C064F.jpeg (271.7 KB, 267 views)
File Type: jpeg CA025956-7019-476B-A956-B120EED4AC64.jpeg (298.3 KB, 295 views)
File Type: jpeg 00EC115B-BF0D-4F5B-8EE8-330AE7B37BC7.jpeg (87.0 KB, 249 views)
Old 09-26-2022, 05:36 PM   #5
That sensor should be bolted to the left side of the intake manifold. In the photos you posted, it appears to be on top.
I've attached a photo of the mounting location.
Old 09-26-2022, 05:45 PM   #6
https://cdn.shopify.com/s/files/1/02...f?v=1636701098
The link above should show the EFI system layout on page 94. The Intake Pressure Sensor is the part in question I believe.
Old 09-27-2022, 09:53 AM   #7
You are correct. I pulled the sensor to get a better photo of it. You are also correct about which sensor it is, however that wasn’t the issue. The seller recommended checking the idle gulp valve screw and adjusting counterclockwise in 1/4 turn increments and then testing after each adjustment. That was the issue. I had to go almost 1 1/2 turns counterclockwise but the bike runs and revs great now even from a cold start. It’s likely that unplugging the pressure sensor was preventing the EFI system from tuning the mix and let the bike run a bit better misleading me. I’ll make a video on it because I have some fine tuning to do still but here is a photo of the adjustment screw. It’s best to remove the canister from its mounts to make it easier to get a screwdriver on the screw.
File Type: jpeg AC836759-B6A2-4D02-B79E-C434815E0AE8.jpeg (71.7 KB, 262 views)
Old 09-27-2022, 12:05 PM   #8
Glad you got it figured out! Happy riding!
Old 09-27-2022, 01:12 PM   #9
Me too! Thanks for the help!
- Nick
2022 BD125-10 XPRO Vader
- ZS 190 Swap
- 17T Front Sprocket
- Nibbi 48MM Intake Pod Filter
- Nibbi Clutch and Throttle cables
2022 Lifan KPR200
Stock... for now.
Old 09-29-2022, 11:45 AM   #10
KPM   KPM is offline
Glad you got it figured out.
I'm sure a lot of others learned something new about that engine, like W T H is a gulp valve. Even the manual linked above doesn't talk about it, only mentions the screw's location 1x, but doesn't explain its function.
For those interested how a gulp valve works....
https://mossmotoring.com/gulp-valve-...fire-solution/
Now we know how to get these bikes to backfire if we want to.
Old 12-12-2022, 12:05 PM   #11
I have fixed it, folks! Video is in the OP and below:
- Nick
- ZS 190 Swap
2022 Lifan KPR200
Stock... for now.
engine dies, idle issue, kpr200
