09-13-2022, 05:29 PM | #1 |
Venom X22R 250/DF 250 dies when I pull clutch
Every time I pull in my clutch to stop at a light the bike dies no matter what gear. Also wont start without throttle in any gear even neutral. Already checked clutch cable slack. Someone PLEASE HELP! Has this happened to anyone else?
09-13-2022, 05:35 PM | #2 |
What rpm's do you have the idle set at? Should be around 1500-1600 rpms. Also have you done valve adjustments yet? Tight gaps on the valves will not let the valves seal once warmed up. You may also need to adjust the idle mixture.
09-13-2022, 05:51 PM | #3 |
Would any of these things cause the bike not to start spontaneously? Rode home from work fine now its not working
09-13-2022, 05:54 PM | #4 |
Yes, especially the valves if they are set without the proper gap.
09-13-2022, 06:03 PM | #5 |
Thanks, will look into this now
09-13-2022, 06:13 PM | #6 |
Any resources available online that you know of with any information regarding these adjustments. I dont have my user manual anymore
09-13-2022, 07:20 PM | #7 |
You can use The Honda CRF230F manual and You Tube as a good resource. I'll post a link to the manual as soon as I can.
09-13-2022, 09:07 PM | #9 |
Glad I could help.
09-14-2022, 07:49 AM | #10 |
As promised, here the CRF230F Service Manual.
