Nibbi PE28
Carb replacment question?
If I replace my Xpro Hawk 250 stock carb with a Nibbi PE28, will I need a different manifold or will it bolt on to the existing one, and also will the air intake hose fit on the new carb? I was also wondering what is the benifit and gains I can expect if I change it out? Thanks for any advice!!!! |
Get the PE28FL .https://a.co/d/cBMV2jn
Thank you
Thanks Jerry!!!!
Would you get a jet kit as well, or will the jets it comes with be enough? |
The jets that come with it might be enough for a stock engine. It wouldn't hurt to have extra jets if you do any other engine mods.
Tags |
carb upgrade |
