09-02-2022, 07:16 AM | #1 |
KPM200 - Oil Strainer Cover Bolt
Does anyone know what this bolt is for ? Not sure if it's a bolt or a drain plug of some sort (It's not the crankcase oil drain plug).
09-02-2022, 07:30 AM | #2 |
That's the cover for the oil screen. You need to remove it to clean the screen when doing an oil change.
09-02-2022, 07:38 AM | #3 |
Here's a service manual for the KPR. Engines are the same so should help with any engine work you need to do. https://cdn.shopify.com/s/files/1/02...f?v=1636701098
