Looking for Valve Cover Gasket for TBR250
I need to replace the valve cover gasket for my 2020 TBR 239cc engine. I am having a hard time finding one online. Any suggestion?
I'd give PowerSportsMax and ask if this works or if they have the gasket. They sell the TBR250 and looks like they have a large selection of parts.
https://www.powersportsmax.com/produ...ducts_id/13052 |
$86!!!!
These guys might be helpful: https://www.taotaopartsdirect.com/ap...arch/?q=gasket Also check with these guys. If they don't list it, maybe they can get it. They seem to be good to work with. https://www.vmcchineseparts.com/collections/gaskets You might need to send them a pic of your current gasket, or the valve cover mounting surface. Can you just re-use your current gasket, with some gasket sealant?
2021 Lifan Xpect--sold 2022 Lifan KPX 1972 Honda CT90--The Carrot 1969 Honda CT90--The Tomahto Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Climate: The Movie https://www.youtube.com/watch?v=A24fWmNA6lM How our government really works https://www.youtube.com/watch?v=QjadCd0VRBw Question all authority.....think for yourself Last edited by TominMO; 08-30-2022 at 08:56 PM. |
I would reccomend making one yourself if you have yhe kno how. Or re use old with gasket maker/ sealer. Not sure how cruicial valve cover is too compression of your model but usually gasket maker should b sufficient in many cases for valve covers
looks like a standard cg200/250 cover gasket.
The CG125/150 valve cover gaskets are a little smaller same pattern. Sorry its an Australian seller but if you get/find a similar kit pretty good chance some/all the gaskets will work https://www.ebay.com.au/itm/27404477...item3fce577cf7 |
