08-27-2022, 06:51 AM | #1 |
2022 Brozz 250 issue wheel/sprocket studs
I think I have an issue with the sprocket mounting studs. I'm noticing some clicking noise when I first start moving in first gear. It sounds like the chain is skipping or engaging the sprocket at an angle causing the sprocket to engage the sides of the chain. I think the sprocket is moving at an angle under torque.
Please note, the chain is adjusted to proper tension. It appears that there is quite a bit of space between the wheel and the sprocket, exposing the studs. I'm wondering if the bushings are seated to deep, sprocket out of tolerance, wheel out of tolerance, or a combination of all? Here is a link to a photo on I posted on the "Bashan 250 owners of America" FB group... https://scontent-lga3-1.xx.fbcdn.net...QA&oe=630E240E Last edited by DualSportJourney; 08-27-2022 at 08:01 AM. Reason: added link to photo |
08-27-2022, 05:54 PM | #2 |
Is the rear sprocket flipped around the right way? Can't tell from the image but the rear sprocket has to go so the studs seat and lock* correct, which will effect chain alignment.
The studs will show a bit as its a 'floating' cush hub. |
10-16-2022, 11:30 PM | #3 |
A thorough check with a tape measure revealed that my rear axle alignment marks on the swing arms were significantly off. Re-align your rear wheel by measuring from the center of the swing arm bolt to the center of the rear axle.
