Old 08-08-2022, 11:47 AM   #1
Doubledown   Doubledown is offline
bd125, Lil Duc, Grom Clone EGR Block Plate
Hello everyone,
Recently purchased a bd125-8 and going through the usual motions of replacing safety parts, gearing and am no onto the carb and removal of emissions.
I have been doing searches for EGR, EGR Plate, EGR block etc, and seeing posts with people having a plate and gasket for this but no reference of where they found one that fits or if sourced intended for something else and made them work.
Can anyone tell me is this is a plate block of kit and where I can get it or what parts I can get to block the EGR port on the head?
Thank you,
Old 08-08-2022, 01:35 PM   #2
franque   franque is offline
Most people make one just out of a small piece of mild steel, like the steel from the crate, drill two holes, put a gasket on it (usually homemade from a small piece of thin cardboard like a cereal box), and let 'er rip.
Get a thin piece of steel and a grinder, and shape until it fits. It's not something people usually buy due to the simple nature of the construction necessary.
Old 08-09-2022, 10:41 AM   #3
4T_Goblin   4T_Goblin is offline
4T_Goblin's Avatar
Go on ebay and search egr block off plate gy6
2020 Vader X-Pro X-7
2019 Kawasaki Ninja ex400
2022 Lifan KPX 250
Old 08-09-2022, 10:52 AM   #4
I did see those, just wasn't sure that fit whatever motor these are. Thank you.
On that topic, is there a motor model number on these clone bikes (like GY6) I should be searching for rather than "Grom / SSR Clone (Part Name)"?
Thank you
Old 08-09-2022, 01:27 PM   #5
4T_Goblin's Avatar
The engine on that model is 154FMI-3 and if not that exact model then something very close to that.
2022 Lifan KPX 250
Old 08-10-2022, 09:42 PM   #6
CheapThrills   CheapThrills is offline
I plugged the end of the tube with epoxy putty. Holding up, might upgrade later to a plate but the putty was an easy addition. https://mymotorcycleblog.com/boom-va...cc-grom-clone/
- My 3 Bikes:
1. TaoTao TBR7 (My TBR7 Upgrades)
2. Boom Vader (FYI: My Boom Vader Upgrades)
3. 1978 Suzuki SG750
Testing a YouTube Channel
Old 08-18-2022, 02:00 PM   #7
Thank you. Looking around not seeing definitive numbers on tappet adjustment. Do these also run at .004" Intake and .006" Exhaust?
Old 08-18-2022, 05:22 PM   #8
4T_Goblin's Avatar
I have mine at .004/.005 but you can run them from .002/.002 or .003/.005 , these little engines are forgiving
2022 Lifan KPX 250
Old 08-19-2022, 03:35 AM   #9
Big Bird   Big Bird is offline
Big Bird's Avatar
Thank you
The booms are kinda a odd duck with a yx top end, Lifan bottom end, and a ssr 54x54 bore and stroke.
2020 Boom Vader Gen 2
2019 CSC TT250
2021 Kayo Fox 70
Old 08-19-2022, 07:43 AM   #10
4T_Goblin's Avatar
I'm rebuilding my transmission and adding the 141bbk to mine and I noticed the yx logo on the head. I thought it was a fake label haha
2022 Lifan KPX 250
