07-31-2022, 02:29 PM | #1 |
Lifan KPR 200 vs KP 200
So I’m close to pulling the trigger on either the KPR or KP 200. I’m not really considering the KPM because the styling isn’t as appealing to me. These all appear to essentially be the same bikes with different fairings. Are there other differences or advantages that aren’t so obvious?
One thing that wasn’t clear is whether the KP LCD dash has a gear indicator. I’m a new rider and it’s a minor assist as I learn. |
07-31-2022, 08:03 PM | #2 |
I think they all have gear indicators. The kpr has skinner tires than the kp. And the rear sprocket on the kp is the same as the KPM, and harder to find. The kpr will melt a higher top speed, due to the fairings.
07-31-2022, 11:33 PM | #3 | |
I’m leaning towards the KP at the moment. |
08-01-2022, 06:12 AM | #4 | |
Basically, it just depends on what you want to do with the bike and what kind of style you want. Each one has pros and cons. Kp200: Wider, more easily found tires. Less fairings to remove for maintenance. But, harder to find a rear sprocket. Lower top speed. KPM200: Sportier appearance. Higher top speed due to fairings. Easier to find rear sprocket. But, more stuff to remove for maintenance. And awkwardly sized tires. |
08-02-2022, 03:04 PM | #5 | |
https://www.chinahao.com/Product/551...i_shatter_rack They also have the fairing parts that are inexpensive as well so I would get what you really want. https://www.superbuy.com/en/page/sea...keyword=kpr200 |
