Old 07-02-2022, 02:58 PM   #1
zscr   zscr is offline
Taller tire profile
So I have a Zongshen bike(ZS250GY-7), it’s similar to the csc tt 250 but with basic suspension and a 19” front tire.
My rear tire is already very worn(4000km~ 2500miles), they are the same tire that the csc tt 250 comes with( centrao dual purpose) and so far I really like them. The problem is they are not available to buy in my country.
So far the only options I found locally that fit the weird (19f-18r) configuration are the Michelin Sirac(80/20), Ax41 adventure cross and Rinaldi rt36.
I am really liking the Ax41 however the profile is 100/90-19 which is a taller tire compared to the stock 90/90-19, what can I expect from this change? The rt36 are very cheap but from what I researched they are bad in wet conditions.
Also if I wanted to change the front rim to a 21 do I need to the change something in the rear? I guess I would also need to adjust the speedometer.
Old 07-02-2022, 03:10 PM   #2
BrokeAss   BrokeAss is offline
BrokeAss's Avatar
You can expect the front to be raised by 9mm.
Might actually fix the optimistic speedometer.
