Old 06-27-2022, 06:05 PM   #1
DIRTYTURBO   DIRTYTURBO is offline
Ninja clone BD125-11 gt neutral issues
Okay so my bike has a little over 300 miles on it and runs and drives fine
But when down shifting it keeps wanting to go from third straight to neutral
Does anyone know if this is normal? Thanks!
Old 06-27-2022, 06:54 PM   #2
I can't answer the question personally, but Pete, the owner of Kronik Racing is a kind of Boom Vader 125 guru, and since these use the same engine, would be able to answer you. www.kronikracing.com
Old 06-27-2022, 10:26 PM   #3
dirtbkr188   dirtbkr188 is offline
dirtbkr188's Avatar
Is the shift pattern 1dn-3up?
Old 06-28-2022, 02:30 AM   #4
Yeah
Old 06-28-2022, 08:14 AM   #5
dirtbkr188's Avatar
The ridge on the shift star between 2nd and neutral is much smaller than the ridge between 2nd and 3rd, making it easier for the shift actuator arm and detent arm to drop the drum into neutral when downshifting.
Click HERE
Old 06-28-2022, 10:03 PM   #6
!!!UPDATE!!!
shorting the shift from 3-2 helped a lot
Also I noticed that the gear shift was loose so fixed
That and it shift perfect THANKS!
125cc, boom
