Old 06-25-2022, 04:14 PM   #1
iLawrence111   iLawrence111 is offline
Angry Hawk 250 rear wheel spoke size
I know this has probably been asked on here before but without all of the extra nonsense, is anyone able to post a link to a site where I can buy spokes for a hawk 250 rear wheel? Please and thank you.
Old 06-25-2022, 05:03 PM   #2
These work.
https://www.aliexpress.com/item/2251...apt=4itemAdapt
From this thread. https://www.chinariders.net/showthre...rR0BW8hP9MBfNw
If you need help searching things, instead of searching on the forum directly, which I have always had hit or miss luck with, search for it on google with chinariders.net at the end of your search query. I tend to find more results that way
Old 06-26-2022, 12:58 AM   #3
Head Scratching
Ouch, so I guess no luck going for a ride within the next 4 weeks bc of that delivery time?
Old 07-02-2022, 06:51 PM   #4
Update
Found spokes that work on ebay. Not sure how long this link will work but here you guys go. https://www.ebay.com/itm/27479652598...kAAOSwHhVgnXXq
Old 07-07-2023, 06:38 PM   #5
chxrs   chxrs is offline
I'd rather not spend $30 on spokes, so I've decided to fabricate some. I know that the spokes are 4mm diameter, and around 6 inches long, so I've bought some solid steel rods that are 4mm in diameter. They arrive on 7/11/2023 and I'm going to use a die to put the right threads on the end, then I'll forge them into spokes with the head and bend. I'll let you all know how it goes. All else failing, I'll just bend the metal into hooks and hook it though the hubs, but I am going to try to fabricate spokes that are as close to original as possible.
Old 07-07-2023, 09:26 PM   #6
Sounds like a fun exercise, but if you think 30 for a whole set is bad, I've paid more than that for one spokes with matching spoke nut on real Hondas lol.
hawk, hawk250, spoke, spokes, wheel
