Old 05-21-2022, 09:59 AM   #1
GPappy   GPappy is offline
Tao 125 Service Manual?
I have done a google search and it appears that there is no service manual for the Tao 125 but I thought I would check to see if anyone had found one. I also read somewhere that the engine may be a knock off of a Honda engine and if anyone could confirm the rumor. If so maybe a Honda manual might help.
I just picked up 3 Tao 125's that are not running. The person I purchased them from said that they ran fine last fall but when they got them out this spring they would not run. He took them to a small engine repair shop that did some disassembly and gave him an estimate to repair that was more than they were worth. He has no mechanical aptitude so just unloaded the lot. I am a pretty good shade tree mechanic so I am going to take a shot at it but given that there has been some disassembly I was hoping to find a manual.
Thanks in advance for any support.
Old 05-21-2022, 01:48 PM   #2
CaptainCanuck   CaptainCanuck is offline
CaptainCanuck's Avatar
I don't really think any of these chinese bikes/atv's have service manuals, at least none that I've ever seen. I had a couple of owners manuals for GIO ATV's and they were kind of a joke as well, no real info.
Standard troubleshooting methods apply, or google searching symptoms for the model you have might give you the information you are looking for to get them going. Also, asking here is a good step as well, lots of people here with experience on these chinese bikes. Quite often the issue is simply plugged jets in the carb from sitting and or a dead battery.
Old 05-21-2022, 05:52 PM   #3
Agree about the carb. They are so cheap that's it's just easier to replace them than fiddle;
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I have this one on my grandkids 125cc and it works great.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 05-22-2022, 02:06 PM   #4
Thank you for the reply. Unfortunately they have been partially disassembled by the guy that was trying to fix them. The shift levers and one of the clutches are out so I was hoping to get an idea of how to reassemble. I can probably take one of the good ones apart to figure out the clutch but not sure how the shifters are mounted.
Old 05-22-2022, 05:12 PM   #5
Here's a youtube video on clutch replacement on the Tao 125, it might show you the info you need to reassemble? Hopefully anyway. Cheers!
Old 05-22-2022, 08:19 PM   #6
Thank you, I will take a look.
