Performance advice?
hallo everyone
![]() ive had a flick through and id just like some oppinions on the following. at the moment i have a fairly uninspiring 125 which has bad clutch plates, anyone know of a guide to replace them? i hear the carbs are a cheap copy of a keihein, is it possible to get the genuine one for a bit of extra performace as theyre more precisely made? or even a bigger bore carb? ones off ebay? Exhaust? i know on 2 strokes they play a major role, my end can has disintegrated so i need to do something, thinking about chopping it and fitting a stubby pit bike can :wink: im considering upgrading the engine cc to a 200cc or even 250cc? whats the best way to go about this 1 : get a brand new or good cond chinese 200/250cc engine, any wiring discrepencies here? i dont think these engines would perform that much better though? 2 : find a honda engine, from what i can tell a honda cdx 200 engine or xr250 engine will fit? anyone know of a model list that uses compatible engines? anyone gone down this route before? 3 : fettle with the old lump, sounds complicated being 4 stroke but its an option, problem is finding the bits that fit? is there a supplier of bits such as; flowed heads or 4v heads? camshafts crankshaft better quality clutch upgraded bearings and such? even a potential 6th gear? performance cdi? i know my way around a 2 stroke and have built a 4 stroke brushcutter engine, i think if i worked from a hayes manual i might be able to sort something ![]() just looking for advice really or anyone done owt like this before? care to show your work cheers for ya help sam ![]() |
Hey Sam,
Welcome aboard. If I were you, I'd pick up a complete engine on eBay. They have some good deals on 150 and 200's that come complete. Should be bolt in and go. Go to eBay and search for Lifan and see what's there.
Fettle?
NOT a term I expect to hear here! LOL Sounds like you have a high mileage/abuse bike, probably best to simply survive, patch up as needed to keep it rolling. |
