Old 04-15-2022, 04:04 PM   #1
Sparrowhawk   Sparrowhawk is offline
Help with Torque via new sprockets
Original gearing on the Tao Tao Raptor is 15 teeth up front and 38 teeth in the rear. I've found on that I can get a 14 tooth up front and a 41 tooth for the rear.
Those of you who have changed your sprockets (a lot of Rhino owners have, I know) do you think this upgrade is worth it to be able to have more hauling torque even though this motor is a GY6?
Thanks in advance.
Chris
Old 04-15-2022, 04:19 PM   #2
I've done some math: 15/38 =2.53. 41/14=2.93.
2.53-2.93= -0.4. Divide that by the original ratio: -0.4/2.53 =0.15810. Multiply by 100 for percent and I get -15.87 percent reduction in top speed so if it was 35, I'll now have a top speed of 30 and (this is the part I'm unsure of) I will gain 15 percent more torque.
Old 04-17-2022, 07:14 AM   #3
buzz   buzz is offline
Hj if you want more power this should work for you.
Old 04-18-2022, 12:04 PM   #4
Thanks buzz, do you think it will matter that this is a gy6 motor--that is, will I still need to mess around with variator weights and the clutch springs too?
