Old 04-11-2022, 01:34 PM   #1
Ftpdaplug   Ftpdaplug is offline
Head Scratching hawk 250 dlx i need aftermarket throttle cable
i need and aftermarket replacement for hawk dlx throttle cable i cant find any
Old 04-12-2022, 05:05 PM   #2
hawkventure   hawkventure is offline
Hey OP, oddly enough I rebuilt my whole throttle assembly to work with easier to find aftermarket cables last week. If you don't want to go full try hard it looks like CSC does have stock throttle cables for the TT250 which likely work. https://cscmotorcycles.com/stock-rep...s/body/cables/
I tipped my bike over and broke something in the actual throttle assembly so I had no choice but to rebuild given I didn't like the OEM throttle assembly much anyway. So IF you want to add some extra work and cost I do like the way this has worked out for me so far.
Basically I found a cheap aftermarket throttle assembly and just bought it on a whim. It fits and the cable is about the exact length you would want to slap it in there except the cable end is not the barrel style where the cable connects to the motor. So I went to an auto parts store and just bought an adapter kit like the one I listed and the smallest size fit. The only problem was that the stock barrel adjuster thing at the bottom wasn't matching up right. So I grabbed a standard bicycle one (7mm) drilled out the hole it needs to fit in and slapped it in there like the picture. IF you wanted to be slick you could tap it so you can use the barrel adjuster as a second point of adjustment but I found the adjustment on the bars to be more than enough for me.
Throttle Assembly: https://www.amazon.com/dp/B07SY7YGK2...roduct_details
Barrel End adapter: https://www.amazon.com/Dorman-3336-C...ve%2C69&sr=1-1
barrel adjuster: https://www.amazon.com/FAVOMOTO-Adju...ve%2C71&sr=1-7
Old 04-12-2022, 05:06 PM   #3
here is a pic
Old 04-12-2022, 05:31 PM   #4
Oldenslow   Oldenslow is offline
Nicely cobbled up, hawkventure. Nothing quite as satisfying as successful make-do mechanicking...
Old 04-16-2022, 06:01 PM   #5
That may be the nicest thing anyone has ever said about my Hawk xd.
hawk dlx 250 efi
