Valve Adjustment Tools
I was going to get a nearly $24 valve adjustment tool to adjust the valves with my son on his new (20 year old!) Civic. Just couldn't spend that much, though it is a nice tool. I kept looking. The Honda has a 10mm lock nut and square head valve stem like the Storm and TBR7, so I expanded the search to both problems...Then I ran into this tool called a "Motorcycle Scooter Valve Tappet Engine Valve Screw Repair Wrench, Adjusting Square Hexagonal Hole Tool Spanner Tool"
[ATTACH] It has three different square socket sizes on the T-handle. The largest is on the long arm. The pass-through socket sizes are 10mm and smaller (but not 8mm. maybe 9?). $8 on Amazon right now, got it next day/today! ![]() I verified the 10mm side on a valve cover bolt, so right then it occured to me that these are all you need to do the whole job (and a fat screwdriver to open the window to see the TDC mark ![]() I struggled with a needle nose plier to hold the square post while tightening the lock nut when I adjust the valve lash. This will be MUCH easier. Last edited by Thumper; 03-24-2022 at 07:34 AM. |
Those are good tools. As long as the T-handle is, you would have to remove the gas tank I think. I can get by fine by just lifting up the rear of the tank on my X-pect with a piece of wood, and using a small open wrench or adjustable wrench on the square post.
I like to set my gap a little wide with the feeler gauge, then if/when it gets smaller when I make the adjustment, it will be where it needs to be. Or I might turn the square post a few degrees CCW to make up for it going CW when I tighten the lock nut. Here's the Amazon link to the tool: https://www.amazon.com/Motorcycle-Sc...s%2C106&sr=8-1
Yup, a secure socket on the square head is the goal. It will reduce that "tightening" effect when you cinch down the lock nut.
BUT, there are three different square nut sizes on that Tee... The one on the long end of the Tee is the biggest, might be good for the Honda Civic. The two on the short legs are more like CG230 sized. I will verify the fit soon. Having a socket with a comfortable levered handle, THROUGH the locknut wrench is sweet ![]() |
Fits!
It is the smallest square socket, on one of the short sides of the Tee. Here it is alone on the valve stem:
And here it is connected, passing through the lock nut wrench: The square socket on the long end of the handle is much bigger (see it in both pics). I hope that fits the Honda Civic (plenty of room/clearance). I didn't bother to remove the valve cover or the hoses on the "EGR valve", but if I do, there will be ample room for adjustment. At eight bucks, I might ordering a second one and just cut off the other side of the Tee handle for easier access under there on one of them. The spare Tee will be for in case I need the slightly larger square socket on the other side of the Tee for something! Sweet inexpensive tool. |
^^ Nice reporting and pics. Have an extra cookie on me.
I simply cannot find "threads" on this site.... so I'll post what I have here...I bought a rear spring for my RX4, from Maximum Motorsport's in CA..... part number "HYP47508225"
...then after taking my money sent me a receipt and said it is on back order and will be 2 weeks or longer till they send it..... but it "SHOULD" Be the right size I hope.... ..... and thanks for the valve adjusting tool info... I think I'll grab one ! looks alot easier than what I had in mind!.....thanks.... Bob.....
It's too late when you've gone too far ! |
Good luck on the spring. I hate it when vendors take the payment when the part isn't in stock.
I had a friend that lived in Weed before he became expatriot retiring in Beliz. You have lots of interesting places to ride. We hiked Shasta with a base camp up on the meadow below the summit about 30 years ago. What a memory! |
Yah that is definitely frustrating... but a guaranteed sale that way for them.
I ran into a problem with my RX4 yesterday it got way too hot .... up to the last digit on the temp gauge ! I checked the coolant and it's full.... so I was scratching my head.... maybe the fuze to the electric radiator fan eh ? as I haven't heard it come on ...ever even yesterday when it was very warm.... could be the problem.... or perhaps it's switch.... odd one for a brand new bike ! ..... Bob.....
I’m looking at this little set for the x-pect.
Same size valve adjustment nuts and whatnot?
2020 Lifan x-pect |
#11 | |
Oh, I did get a second one. I mean $7 I will give it to one of my son's! |
#12 |
I've found that a bit for square socket wood screws is the same size. So, if you have one of the screws you can bend the head 90 degrees to make a mini wrench. That's what I used for a Yamaha XT225 that I used to have. I included the DIY wrench with it when I later sold it to a buddy.
#13 |
I was going to get a nearly $24 valve adjustment tool to adjust the valves with my son on his new 20 year old! Civic. Just couldn't spend that much, though it is a nice tool.
I kept looking. The Honda has a 10mm lock nut and square head valve stem like the Storm and TBR7, so I expanded the search to both problems. Then I ran into this tool called a Motorcycle Scooter Valve Tappet Engine Valve Screw Repair Wrench, Adjusting Square Hexagonal Hole Tool Spanner Tool. |
#14 |
Just reporting back here that this does indeed work with the xpect.
The little piece with the square hole that rotates the very top of the valve is useful. However, the larger diameter piece is useless. Easier just to use a wrench. Edit:. When I say the big piece is useless, I don’t mean it doesn’t fit. It does. It’s just too hard to manage both pieces at once and you end up dropping things constantly. A wrench is easier to manage than the larger piece of this set.
2020 Lifan x-pect |
#15 |
Thanks for letting us know.
I use a long needle-nose pliers for the square post, and a 10mm wrench for the locking nut.
