Rebuilds
does anybody know where I can get a rebuild kit for a Tao
250 or or what compatible parts will work for a full rebuild |
CSCmotorcycles has the best selection of motor parts but there tt250 has a counterbalanced version of the cg engine and I'm not sure if all the parts will interchange
A full rebuild changes according to how f ed up your engine is.
Assuming this is for a CG engine, and assuming you are talking a full rebuild - new crank, rod, bearings, piston, rings, cylinder, head, then the rebuild kits basically boil down to 2 things. Engine size (bore and stroke) and counter balanced or not.
If you are just looking into a new top end - cylinder, piston, and head - then pretty much all of them are the same. The only real difference will come down to quality and pricing, which unfortunately don't always line up like you would think they do. If the top end rebuild is what you are after then I do recommend getting the parts from CSC for the TT250 or from Peace Sports for the Brozz. Price wise it actually doesn't work out half bad, and the quality of the parts is guaranteed to be better/consistent than what you can find elsewhere. Plus, if there is a flaw or damage, the return/swap process is going to be much easier. Otherwise, take your pick from the hundreds of options on ebay or aliexpress.
Tags |
bottom end, overhaul, rebuild, rebuilds, top end |
