03-10-2022, 09:50 AM | #1 |
Brand new
Hey y'all,
After much research, I bought my BRAND NEW 2020 Bashan Brozz on from Jeff at Peace Sports in Atlanta. I live in Upstate SC, so I hopped on I-85 South towards Atlanta. Got there and loaded the blue Bashan, fully assembled, into my 2005 Silverado 1500 and brought it home! This is my first bike and i'm super stoked about learning to ride. Any suggestions on what needs to be done right out of the gate? It came with upgraded Pro Taper handle bars, an hour meter, and an upgraded chain. The horn does not work, kind of a bummer. Any suggestions are welcomed. Looking forward to joining the discussions! David - AKA SCsandman |
03-10-2022, 10:06 AM | #2 |
Welcome aboard and congrats on the new Brozz. As far as the horn not working i would contact Jeff for a replacement horn as the bike should be under warranty.
03-10-2022, 01:58 PM | #3 |
Hello David and congrats on the new Brozz! I think the blue one is one of the best colors. The Brozz is an excellent bike and lots of fun, especially when you start making it your own. Usually it's best if you check the valve clearance on it and you still might want to, although with you buying it from the dealer they might have done that already.
03-10-2022, 09:27 PM | #4 |
My horn didn't work, but after unplugging wires and replugging, it worked. Needs a little dielectric grease.
2018 Bashan Storm(sold) 2016 Magician 250 |
03-11-2022, 05:34 AM | #5 |
Congrats on the new bike!
Working with Jeff at Peace is usually a good experience. I might suggest to check the horn wiring with a voltage meter or light to determine if you're getting voltage there before requesting a new horn just in case it's in the switch or wiring.
