Old 02-21-2022, 07:15 PM   #1
Boatguy   Boatguy is offline
Boatguy's Avatar
Been asking around. Asking here too. Can I store my bike laying down?
I often ask questions on huge motorcycle forums thinking the sheer number of people means the knowledge is there. Half the time you guys know more than they do.
So I’m wondering. Is it ok to store my bike horizontally? Laying down?
2020 Lifan x-pect
Old 02-21-2022, 08:14 PM   #2
buzz   buzz is offline
i would not do that
Old 02-21-2022, 08:23 PM   #3
ExMxer   ExMxer is offline
ExMxer's Avatar
Big no on that one. In fact, Kawasaki recommends not to even store them on their side stand for extended periods of time. Store it on a center stand, centered upright
Old 02-21-2022, 08:32 PM   #4
Boatguy's Avatar
Can i ask why?
I see things like this, which is what I’m trying to do:
2020 Lifan x-pect
Old 02-21-2022, 08:36 PM   #5
Boatguy's Avatar
On the other forum most people said no problem or laughed at me for asking.
I killed a generator by tipping it the wrong way once so I do have concerns.
2020 Lifan x-pect
Old 02-21-2022, 09:02 PM   #6
Storing on the side stand for long periods is bad for one reason. No oil is in contact with the clutch when on the side stand. If stored long enough like that the clutch will fuse together eventually.
As far as laying it down on the side. Same issue if it's laid down on the left side, but not a problem at all on the right side. The bigger issues mainly have to do with fluids. The oil will potentially seep past the rings and fill the combustion chamber. Possibly Leak out of the fill port on the right side, and the timing plugs on the left side. I also would want to remove the fuel tank or make sure it's completely empty.
Beyond all of that, realistically speaking storing it on the side briefly won't hurt much. Long term (several months) is where issues arise.
Old 02-21-2022, 10:40 PM   #7
GlennR   GlennR is offline
Originally Posted by Boatguy View Post
Can i ask why?
Those guys need bigger boats.
Old 02-22-2022, 10:34 AM   #8
Boatguy's Avatar
That’s a really good explanation. Thank you.
One follow on question.
If you were to lay it on the right side for weeks at a time, would it still be ok because the clutch is in the oil?
It would be significantly better for my visibility on the big boat to have it on its side. Otherwise it will interfere with my field of vision.
What if I kept it not completely horizontal, but up just a little bit so that the combustion chamber was higher than the oil sump crank case area?
2020 Lifan x-pect
Old 02-22-2022, 11:16 AM   #9
I'm curious about how you're planning to load & unload the bike into & from the boat? Where do you plan to take it & how long are you planning to store it on its side?
Old 02-22-2022, 11:21 AM   #10
Boatguy's Avatar
That’s all sorted out. Small boat, gin pole, etc.
Taking it wherever ashore and would like to store it on its side indefinitely actually, in an ideal world.
2020 Lifan x-pect
Old 02-22-2022, 12:23 PM   #11
Nospark   Nospark is offline
As Megadan points out, on it's side for long period may allow oil to flow into the cylinder which might cause unwanted hydraulic pressure during combustion stroke. Even after a short period, a few days on its side, you might do yourself a favor by removing the plug and turning it over for a few seconds to blow out any excessive oil that may have settled into the cylinder.
Old 02-22-2022, 12:23 PM   #12
This might keep you a little farther from the alligator's jaws, and can't be punctured. Also, m/c provides power (complete with steering)
Of course, it is not portable and stowable, so not good for portage you can stow!
