Old 02-09-2022, 01:22 PM   #1
KC10   KC10 is offline
Taotao 125 atv
Bought a TaoTao 125 ATV. Do these idle? When you pull your finger off of the throttle it shuts down and you have to keep starting it. It’s this normal?
Old 02-09-2022, 01:53 PM   #2
Bruces   Bruces is offline
Not normal ,try turning the idle screw in a little ,but be careful you don’t turn it up so much that the bike won’t sit without moving .
Old 02-14-2022, 05:39 PM   #3
Douglass   Douglass is offline
Douglass's Avatar
Here are some things to check/Try
* Clean the carburetor
* Adjust idle screw
* see if the air/fuel screw has been messed with. They are usually capped (brass cap) from the factory.
Is this a new or used unit?
