Quality PD24J carb replacement?
Hi.
I'm looking to replace my stock PD24J carb with a quality but inexpensive unit. The scooter is a Dong Fang brand "Razor 150" sold through Redfox Powersports. I see Amazon in the USA has them from 20 to about 50 dollars. I think a 20 dollar carb may be cheap quality wise but the one 50 dollar model I found (GoKart Exports brand) seems overpriced compared to the average price. I just don't know which brand to trust. The bike is 6 months old. (my first motorcycle) I want to replace the carb because I don't have access to the fuel/air mixture screw like you see in this post (It's covered up with what looks to be a solid piece of metal): https://www.reddit.com/r/scooters/co...air_mix_screw/ I know I can remove the plug but I'd rather not and just go with a better quality carb that may preform better. You see no matter how I adjust the idle speed screw, the bike wants to kill easily and I suspect I'm not getting the power I should. I live right at 3 feet above sea level and I understand the fuel/air mixture is factory set for a much higher elevation. I read that someplace because they want to set them at an average that makes most people happy. I have no actual way to determine the exact sea level my fuel/air mixture was set for.. I assume perhaps it's set for the location of the factory where the bike was made. Ya know that purring like a kitten sound you try to achieve, I can never get that. Of course it's possible as a newbie I'm still not adjusting things right and don't need to mess with the fuel/air screw at all. Your thoughts? Thank you. |
Save you money and buy the less expensive one. I can promise you they will be the same no matter what the price is.
drill out the cover, its easy to do and if you still want to spend money, then go ahead and buy a new carb.
